... | @@ -17,7 +17,6 @@ A lot of improvements in all processes and new material properties. Mostly bug f |
- The storage is now derived from the fluid density and the solid bulk modulus. !3159
- Fix bug in temperature equation for non-zero velocity. !3193
- HydroMechanics: Allow linear shape functions for displacement. !3334
- Use MPL properties in HeatConduction process. !3062
- Fix bug in deactivation of subdomains !3065
- Exterior forces output in LiquidFlow and HeatConduction. !3068
... | @@ -58,7 +57,7 @@ A lot of improvements in all processes and new material properties. Mostly bug f |
- Pass variables from previous time step to MPL Property::value() calls where increments are required. All *rate variables were removed in
favor of the increments. !3102
- Use 2D coordinate system for LinearElasticOrthotropic solid material. A bugfix, now allowing 2D anisotropy and solid material orthotropy to be used simultaneously. !3165
- Unused MPL properties are shown as warnings after successful run in debug mode !3197
- Unused MPL properties are shown as warnings after successful run in debug mode. !3197
- Error message now informs user of missing properties on the medium scale. !3337
- Bugfix of a 2D case in MFront's implementation of Mohr-Coulomb-Abbo-Sloan anisotropic model. !3260
- Update interface of the solid material models now accepting MPL Variables. !3261
... | @@ -80,10 +79,9 @@ favor of the increments. !3102 |
- Update the Heat_Transport_BHE PipeNetwork Tutorial to TESPy version 0.3.x API. !3070
- Three-part video tutorial [available on YouTube](https://www.youtube.com/watch?v=BULunRJQRJ0&list=PLU_clTnZqNAeOXENl79kQwn0pgHGittX1&index=1). !3278
- New benchmark based the Liakopoulos experiment for RichardsMechanics- !3175
- New benchmark based the Liakopoulos experiment for RichardsMechanics. !3175
- New test of heat transport in liquid flow with a constant velocity, HeatTransportInStationaryFlow. !3194, !3328
- Fixed a formula display in "BGRa creep model". !3329
- Switched from Pandoc to GoldMark Markdown parser. !3076
- Added troubleshooting web page for runtime issues. !3129
- Web site usage tracking with Plausible, No personal data is tracked. Fully GDPR-compliant. !3168
... | @@ -116,7 +114,7 @@ favor of the increments. !3102 |
## CI & Infrastructure
- `cppcheck`-report !3053.
- `cppcheck`-report. !3053.
- Package DataExplorer into container. !3105
- Unified and local (in the build-dir) Python environment with [Poetry](https://python-poetry.org). !3133
- Python formatting check with black. !3158 and #3044
... | @@ -138,5 +136,5 @@ favor of the increments. !3102 |
- Update exprtk submodule to the most recent master commit ([d312ba9](https://github.com/ArashPartow/exprtk/commit/d312ba91419c9cb12c8279fd3a19096d39dfcb5e)
) dated 1 Jan. 2020. !3112
- Apple Clang (Xcode) 11.0 required. !3115
- New (optional) dependency: HDF5 1.10.5 (!3246, !3295)
- New (optional) dependency: HDF5 1.10.5. (!3246, !3295)
- New (optional) dependency: Libxml2 2.9.10 (!3246, !3295) |
- New (optional) dependency: Libxml2 2.9.10. (!3246, !3295) |
