**NOTE:** This is not released yet!
The current release is a base for the upcoming TH2M process and further extension of the newly implemented non-isothermal Richards mechanics.
The highlights of this release are collected in the overview with details below.
## Overview
## Overview
- The reactive transport process and its Phreeqc interface were enhanced: extended the porosity interface and provide two ways of calculating solid/liquid ratio.
- Many new MPL models were implemented including the Clausius-Clapeyron vapor pressure, the Somerton's thermal conductivity, the FEBEX and PMQ type vapour diffusion, a water vapour density property, a linear latent heat of water property.
Many new material models were implemented including the Clausius-Clapeyron vapor pressure, the Somerton's thermal conductivity, the FEBEX and PMQ type vapour diffusion, a water vapour density property, and a linear latent heat of water property.
- Double structure porosity model in RM
A new process---the non-isothermal Richards mechanics---was implemented and extends our ability for complex thermo-hydro-mechanical interaction simulations further.
- Time dependent excavations
The simpler Richards mechanics process was enhanced by a double structure porosity model, which has been used for simulations with Bentonite.
Modelling of the excavations got a fine-grained time control over the excavation progress.
The development environment...
- CPM
- CPM
- spellcheck, cmake-format, clang-format
- metrics in Gitlab, coverage
