**This is not released yet!**
- !3567 Added optional functionality for irreversible equilibrium reactions to the ChemistryLib.
- !3555 Clang-format all of the code base. Thriving for consistency.
- !3574 Extend integration point data output to solid material state internal variables used by *e.g.* MFront. This makes correct restart possible.
- !3562 Added threshold for Doxygen warnings (16).
- !3570 Enabled compiler warnings for executables.
- !3546 Implementing medium level property to mix thermal conductivities from phases
### Material models
### Material models
- !3563 Added an incremental-type porosity model based on volume balance equation. This porosity model is tailored for the reactive transport process.
- !3572 IdealGasLaw now uses molar mass from VariableArray rather than from another MPL-Property
- !3572 IdealGasLaw now uses molar mass from VariableArray rather than from another MPL-Property.
- !---- New simplistic yet quite flexible Saturation-Capillary pressure relation, mainly for testing and prototyping purposes
- !3579 New saturation-capillary pressure relation, SaturationExponential, mainly for testing and prototyping purposes.
- !3546 Implementing medium level property to mix thermal conductivities from phases.
### Data Explorer
### Data Explorer
- !3578 Elevation of station data can be mapped based on meshes or rasters
### Bug fixes
### Bug fixes
- !3566 Fixed a bug in NodalSourceTerm when the Taylor-Hood elements are used. |
\ No newline at end of file |
### Infrastructure
- !3570 Enabled compiler warnings for executables. |
