# Overview
# Overview
- Implementation of Thermo-Hydro-Hydro-Mechanical (TH2M) fully coupled process. The process is intended for modelling two-component two-phase flow in deformable porous media under non-isothermal conditions. Testing is in progress and development continues, so handle with care or wait a little longer until we're done.
This release features the implementation of the Thermo-Hydro-Hydro-Mechanical (`TH2M`) fully coupled process. The process is intended for modeling two-component two-phase flow in deformable porous media under non-isothermal conditions. Testing is in progress and development continues, so handle with care or wait a little longer until it got more refined.
- Another new process, the StokesFlow process, is mainly used for simulating the low-Reynolds-number incompressible flow in fractures. The Stokes equations are solved using the standard Taylor-Hood scheme. Additionally including the Darcy term in the momentum balance equations, the `StokesFlow` process module is capable of modeling the fluid flow in fractured porous media.
Another new process, the StokesFlow process, is mainly used for simulating the low-Reynolds-number [incompressible flow in fractures](https://www.opengeosys.org/docs/benchmarks/stokes-flow/parallel-plate-flow/). The Stokes equations are solved using the standard Taylor-Hood scheme. Additionally including the Darcy term in the momentum balance equations, the `StokesFlow` process module is capable of modeling the fluid flow in fractured porous media.
Also work continued on new material models, e.g. the Günther Salzer model for transient and stationary rock salt creep, an improved HDF5-based output file handling which allows for [parallel postprocessing](https://gitlab.opengeosys.org/ogs/ogs/-/wikis/Working-with-HDF-data-(examples-h5py)) as well as the introduction of a first iteration of a [Jupyter Notebook based user workflow](https://www.opengeosys.org/docs/userguide/basics/jupyter-notebooks/). Stay tuned for more on interactive computing in future releases.
# New processes
# New processes
... | @@ -162,4 +165,5 @@ A thermal two-phase flow in deformable solid media process. |
# Version info
# Version info
* [!3647](/ogs/ogs/-/merge_requests/3647) MFront based on [TFEL branch rliv-3.4](https://github.com/thelfer/tfel/tree/rliv-3.4)
* [!3757](/ogs/ogs/-/merge_requests/3757) Conan 1.34.0 (optional) |
\ No newline at end of file |
* [!3707] [CMake presets](https://www.opengeosys.org/docs/devguide/getting-started/build-configuration/#available-cmake-presets) require CMake 3.21. |
