... | @@ -95,6 +95,9 @@ Enable node search function work under MPI |
* [!4001](https://gitlab.opengeosys.org/ogs/ogs/-/merge_requests/4001) Added a simple MKL benchmark.
* [!4005](https://gitlab.opengeosys.org/ogs/ogs/-/merge_requests/4005) Run TaskCDECOVALEX2023 with parallel computing
* [!4021](https://gitlab.opengeosys.org/ogs/ogs/-/merge_requests/4021) adds extensive unit tests for OGS's quadrature schemes. Now for each supported integration method and integration on each mesh element type we test, which polynomial order we can integrate exactly.
* [!4012](https://gitlab.opengeosys.org/ogs/ogs/-/merge_requests/4012)
Added parallel computing benchmarks for ThermoRichardsFlow.
### Bug fixes
### Bug fixes
... | @@ -106,7 +109,9 @@ Enable node search function work under MPI |
* [!4021](https://gitlab.opengeosys.org/ogs/ogs/-/merge_requests/4021) Fixes pyramid integration for integration order 1. Note, the location of the single integration point was changed! If you have any restart data with integration order 1, the respective location will silently change. However, that seems acceptable since before the pyramid order 1 integration was just wrong.
* [!4051](https://gitlab.opengeosys.org/ogs/ogs/-/merge_requests/4051) Changes the input storage order of tensorial properties of MPL. Now it is row major, before it was column major. The new row major storage order is the storage order that naturally arises in prj files. The old behavior was not a bug per se, but could very likely lead to subtle errors with asymmetric tensorial properties.
* [!4055](https://gitlab.opengeosys.org/ogs/ogs/-/merge_requests/4055) Fixing a bug in Process::setInitialConditions under PETSc
* [!4055](https://gitlab.opengeosys.org/ogs/ogs/-/merge_requests/4055) Fixing a bug in Process::setInitialConditions under PETSc.
Fixed the errors in the calculation of global PETSc matrix and PETSc vector on envinf test machines.
### CMake
### CMake
