... | @@ -91,9 +91,12 @@ Enable node search function work under MPI |
### Testing
### Testing
* [!3930](https://gitlab.opengeosys.org/ogs/ogs/-/merge_requests/3930) Notebooks are now tested as part of `ctest`. See [docs](https://www.opengeosys.org/docs/devguide/testing/test-data/#notebook-testing) for more info.
* [!3901](https://gitlab.opengeosys.org/ogs/ogs/-/merge_requests/3901) [TRM] Added a benchmark of point heat source for TRM.
* [!4001](https://gitlab.opengeosys.org/ogs/ogs/-/merge_requests/4001) Added a simple MKL benchmark.
* [!4005](https://gitlab.opengeosys.org/ogs/ogs/-/merge_requests/4005) Run TaskCDECOVALEX2023 with parallel computing
* [!4021](https://gitlab.opengeosys.org/ogs/ogs/-/merge_requests/4021) adds extensive unit tests for OGS's quadrature schemes. Now for each supported integration method and integration on each mesh element type we test, which polynomial order we can integrate exactly.
### Bug fixes
### Bug fixes
* [!3932](https://gitlab.opengeosys.org/ogs/ogs/-/merge_requests/3932) Fixed several memory leaks and access bugs.
... | @@ -131,7 +134,8 @@ Enable node search function work under MPI |
### Version info
### Version info
* [!3844](https://gitlab.opengeosys.org/ogs/ogs/-/merge_requests/3844) Update gtest to version 1.11.0
* [!3910](https://gitlab.opengeosys.org/ogs/ogs/-/merge_requests/3910) Minimum Conan version 1.36.0
* [!3951](https://gitlab.opengeosys.org/ogs/ogs/-/merge_requests/3951) Minimum gcc version 9.1
* [!3968](https://gitlab.opengeosys.org/ogs/ogs/-/merge_requests/3968) Update exprtk to newest version Dec. 2021.
