... | @@ -47,7 +47,8 @@ The vapour diffusion and the latent heat terms of TRM |
* [!3871](https://gitlab.opengeosys.org/ogs/ogs/-/merge_requests/3871) Integration order 4 implemented for Tetrahedrals. For an overview over OGS's integration methods see also !4021.
* [!3907](https://gitlab.opengeosys.org/ogs/ogs/-/merge_requests/3907) added new Eigen iterative solvers: BiCGSTABL, IDRS and IDRSTABL
* !3882 adds support for Taylor-Hood elements to Python boundary conditions and Python source terms.
* [!3882](https://gitlab.opengeosys.org/ogs/ogs/-/merge_requests/3882) adds support for Taylor-Hood elements to Python boundary conditions and Python source terms.
* [!3991](https://gitlab.opengeosys.org/ogs/ogs/-/merge_requests/3991) Enable to use 13 node pyramid and 15 node prism.
### Parallel computing
... | @@ -86,7 +87,7 @@ The vapour diffusion and the latent heat terms of TRM |
* [!3930](https://gitlab.opengeosys.org/ogs/ogs/-/merge_requests/3930) Notebooks are now tested as part of `ctest`. See [docs](https://www.opengeosys.org/docs/devguide/testing/test-data/#notebook-testing) for more info.
* [!4001](https://gitlab.opengeosys.org/ogs/ogs/-/merge_requests/4001) Added a simple MKL benchmark.
* !4021 adds extensive unit tests for OGS's quadrature schemes. Now for each supported integration method and integration on each mesh element type we test, which polynomial order we can integrate exactly.
* [!4021](https://gitlab.opengeosys.org/ogs/ogs/-/merge_requests/4021) adds extensive unit tests for OGS's quadrature schemes. Now for each supported integration method and integration on each mesh element type we test, which polynomial order we can integrate exactly.
### Bug fixes
### Bug fixes
... | @@ -95,8 +96,8 @@ The vapour diffusion and the latent heat terms of TRM |
* [!3978](https://gitlab.opengeosys.org/ogs/ogs/-/merge_requests/3978) Fix access of transport porosity as medium property in TRM
* [!3919](https://gitlab.opengeosys.org/ogs/ogs/-/merge_requests/3919)
Enable node search function work under MPI
* !4021 Fixes pyramid integration for integration order 1. Note, the location of the single integration point was changed! If you have any restart data with integration order 1, the respective location will silently change. However, that seems acceptible since before the pyramid order 1 integration was just wrong.
* [!4021](https://gitlab.opengeosys.org/ogs/ogs/-/merge_requests/4021) Fixes pyramid integration for integration order 1. Note, the location of the single integration point was changed! If you have any restart data with integration order 1, the respective location will silently change. However, that seems acceptable since before the pyramid order 1 integration was just wrong.
* !4051 Changes the input storage order of tensorial properties of MPL. Now it is row major, before it was column major. The new row major storage order is the storage order that naturally arises in prj files. The old behavior was not a bug per se, but could very likely lead to subtle errors with asymmetric tensorial properties.
* [!4051](https://gitlab.opengeosys.org/ogs/ogs/-/merge_requests/4051) Changes the input storage order of tensorial properties of MPL. Now it is row major, before it was column major. The new row major storage order is the storage order that naturally arises in prj files. The old behavior was not a bug per se, but could very likely lead to subtle errors with asymmetric tensorial properties.
* [!4055](https://gitlab.opengeosys.org/ogs/ogs/-/merge_requests/4055) Fixing a bug in Process::setInitialConditions under PETSc
### CMake
### CMake
