... | ... | @@ -97,6 +97,7 @@ The vapour diffusion and the latent heat terms of TRM |
Enable node search function work under MPI
* !4021 Fixes pyramid integration for integration order 1. Note, the location of the single integration point was changed! If you have any restart data with integration order 1, the respective location will silently change. However, that seems acceptible since before the pyramid order 1 integration was just wrong.
* !4051 Changes the input storage order of tensorial properties of MPL. Now it is row major, before it was column major. The new row major storage order is the storage order that naturally arises in prj files. The old behavior was not a bug per se, but could very likely lead to subtle errors with asymmetric tensorial properties.
* [!4055](https://gitlab.opengeosys.org/ogs/ogs/-/merge_requests/4055) Fixing a bug in Process::setInitialConditions under PETSc
### CMake
