... | ... | @@ -51,9 +51,9 @@ The vapour diffusion and the latent heat terms of TRM |
* [!3871](https://gitlab.opengeosys.org/ogs/ogs/-/merge_requests/3871) Integration order 4 implemented for Tetrahedrals. For an overview over OGS's integration methods see also !4021.
* [!3907](https://gitlab.opengeosys.org/ogs/ogs/-/merge_requests/3907) added new Eigen iterative solvers: BiCGSTABL, IDRS and IDRSTABL
* [!3882](https://gitlab.opengeosys.org/ogs/ogs/-/merge_requests/3882) adds support for Taylor-Hood elements to Python boundary conditions and Python source terms.
* [!3963](https://gitlab.opengeosys.org/ogs/ogs/-/merge_requests/3963) Enabled equation wise flexibility in the use of compensate_non_equilibrium_initial_residuum
* [!3991](https://gitlab.opengeosys.org/ogs/ogs/-/merge_requests/3991) Enable to use 13 node pyramid and 15 node prism.
### Parallel computing
* [!3805](https://gitlab.opengeosys.org/ogs/ogs/-/merge_requests/3805) [partmesh] Removed the option of `-q` or `--lh_elements` for the impementation of parallel computing with Taylor Hood elements.
