... | @@ -15,6 +15,12 @@ Highlights: |
* [!4247](https://gitlab.opengeosys.org/ogs/ogs/-/merge_requests/4247) MPL: Reimplement VariableArray as own class. Less memory and a little faster. Easier usage.
## TH2M
## TH2M
The TH2M process describes a two-phase, two-component approach, which is fully coupled with thermodynamic and geomechanical processes.
Due to the complex process couplings, many different processes (e.g. in repository systems) can be investigated numerically, including media dry-out and resaturation, consolidation, stress- or deformation-dependent permeabilities, thermal expansion and heat-induced stresses, gas transport processes in fully or partially saturated media and others.
The two-component approach also enables the description of phase transition processes (evaporation, solution) under an equilibrium condition.
To validate the TH2M model, a benchmark suite was created that provides a hierarchical classification of different coupling combinations of the individual processes. This proves the validity and correct implementation of all terms of the model equations.
* [!4131](https://gitlab.opengeosys.org/ogs/ogs/-/merge_requests/4131) Dissolution of gas into the liquid phase, completing the phase transition feature in TH2M
* [!4131](https://gitlab.opengeosys.org/ogs/ogs/-/merge_requests/4131) Two tests validate the dissolution process and the diffusive transport of the dissolved gas in the water phase
