Commit 389da47a authored by phit0's avatar phit0
[ci] pipeline rules for benchmark tests
parent cfb74adc
Pipeline #7425 passed with stage
in 2 minutes and 32 seconds
image: rocker/tidyverse image: rocker/tidyverse
stages:
- test
- benchmark-test
test: test:
stage: test stage: test
tags: tags:
...@@ -28,5 +32,15 @@ test: ...@@ -28,5 +32,15 @@ test:
- "$RETICULATE_MINICONDA_PATH" - "$RETICULATE_MINICONDA_PATH"
- "$RETICULATE_PYTHON_ENV" - "$RETICULATE_PYTHON_ENV"
# script will only run then attempting to merge/push to master # script will only run then attempting to merge/push to master
only: rules:
- merge_requests - if: '$CI_PIPELINE_SOURCE == "merge_request_event"'
\ No newline at end of file - if: '$CI_PIPELINE_SOURCE == "api"'
benchmark-test:
stage: benchmark-test
rules:
when: on_success
script:
- echo Hello World
Supports Markdown
0% or .
