O
Chaofan Chen
09936a4f
09936a4f
9 years ago
Norihiro Watanabe
include comments from TF
74d73777
Branches containing commit
Tags containing commit
3
3 changed files
MathLib/LinAlg/Eigen/EigenLinearSolver.cpp
+0
-1
0 additions, 1 deletion
MathLib/LinAlg/Eigen/EigenMatrix.h
+29
-12
29 additions, 12 deletions
MathLib/LinAlg/Eigen/EigenOption.h
+1
-1
1 addition, 1 deletion
30 additions
14 deletions
09936a4f
@@ -11,7 +11,6 @@
@@ -11,7 +11,6 @@
#include
<boost/property_tree/ptree.hpp>
#include
#include
<logog/include/logog.hpp>
#include
#include
<unsupported/Eigen/IterativeSolvers>
#include
"EigenVector.h"
#include
"EigenVector.h"
#include
"EigenMatrix.h"
#include
"EigenMatrix.h"
29
12
09936a4f
@@ -26,6 +26,8 @@ namespace MathLib
* Global matrix based on Eigen sparse matrix
* The matrix will be dynamically allocated during construction.
class
EigenMatrix
class
EigenMatrix
@@ -52,20 +54,22 @@ public:
/// return an end index of the active data range
virtual
std
size_t
getRangeEnd
const
return
getNRows
virtual
std
size_t
getRangeEnd
const
return
getNRows
R
eset data entries to zero.
r
virtual
void
setZero
virtual
void
setZero
_mat
setZero
_mat
setZero
/// set entry
/// set a value to the given entry. If the entry doesn't exist, this class
/// dynamically allocates it.
int
setValue
std
size_t
row
std
size_t
col
double
val
int
setValue
std
size_t
row
std
size_t
col
double
val
_mat
coeffRef
row
col
val
_mat
coeffRef
row
col
val
return
return
/// add value
/// add a value to the given entry. If the entry doesn't exist, the value is
/// inserted.
int
add
std
size_t
row
std
size_t
col
double
val
int
add
std
size_t
row
std
size_t
col
double
val
assert
row
getNRows
col
getNCols
assert
row
getNRows
col
getNCols
@@ -74,7 +78,7 @@ public:
/// Add sub-matrix at positions \c row_pos and same column positions as the
/// given row positions.
If the entry doesn't exist, the value is inserted.
template
class
T_DENSE_MATRIX
template
class
T_DENSE_MATRIX
void
add
std
vector
std
size_t
const
row_pos
void
add
std
vector
std
size_t
const
row_pos
const
T_DENSE_MATRIX
sub_matrix
const
T_DENSE_MATRIX
sub_matrix
@@ -83,7 +87,8 @@ public:
this
add
row_pos
row_pos
sub_matrix
fkt
this
add
row_pos
row_pos
sub_matrix
fkt
/// Add sub-matrix at positions given by \c indices.
/// Add sub-matrix at positions given by \c indices. If the entry doesn't exist,
/// this class inserts the value.
template
class
T_DENSE_MATRIX
template
class
T_DENSE_MATRIX
void
add
RowColumnIndices
std
size_t
const
indices
void
add
RowColumnIndices
std
size_t
const
indices
const
T_DENSE_MATRIX
sub_matrix
const
T_DENSE_MATRIX
sub_matrix
@@ -92,27 +97,39 @@ public:
this
add
indices
rows
indices
columns
sub_matrix
fkt
this
add
indices
rows
indices
columns
sub_matrix
fkt
* Add sub-matrix at positions \c row_pos and \c col_pos. If the entries doesn't
* exist in the matrix, the values are inserted.
* @param row_pos a vector of row position indices. The vector size should
* equal to the number of rows in the given sub-matrix.
* @param col_pos a vector of column position indices. The vector size should
* equal to the number of columns in the given sub-matrix.
* @param sub_matrix a sub-matrix to be added
* @param fkt a scaling factor applied to all entries in the sub-matrix
template
class
T_DENSE_MATRIX
template
class
T_DENSE_MATRIX
void
add
std
vector
std
size_t
const
row_pos
void
add
std
vector
std
size_t
const
row_pos
std
vector
std
size_t
const
col_pos
const
T_DENSE_MATRIX
sub_matrix
std
vector
std
size_t
const
col_pos
const
T_DENSE_MATRIX
sub_matrix
double
fkt
1.0
double
fkt
1.0
/// get value
/// get value
. This function returns zero if the element doesn't exist.
double
get
std
size_t
row
std
size_t
col
double
get
std
size_t
row
std
size_t
col
const
assert
row
getNRows
col
getNCols
assert
row
getNRows
col
getNCols
return
_mat
coeff
row
col
return
_mat
coeff
row
col
/// get value
/// get value
double
operator
std
size_t
row
std
size_t
col
const
double
operator
std
size_t
row
std
size_t
col
const
return
_mat
coeff
row
col
return
get
row
col
/// get a maximum value in diagonal entries
virtual
double
getMaxDiagCoeff
return
virtual
double
getMaxDiagCoeff
const
return
_mat
diagonal
maxCoeff
/// y = mat * x
/// y = mat * x
virtual
void
multiply
const
EigenVector
x
EigenVector
y
const
virtual
void
multiply
const
EigenVector
x
EigenVector
y
const
@@ -120,7 +137,7 @@ public:
y
getRawVector
_mat
x
getRawVector
y
getRawVector
_mat
x
getRawVector
/// return
if
th
is
matrix is al
ready assembled or not
/// return
always true, i.e.
th
e
matrix is al
ways ready for use
bool
isAssembled
const
return
true
bool
isAssembled
const
return
true
#ifndef NDEBUG
#ifndef NDEBUG
09936a4f
@@ -41,7 +41,7 @@ struct EigenOption
/// Preconditioner type
PreconType
precon_type
PreconType
precon_type
/// Maximum iteration count
long
max_iterations
std
size_t
max_iterations
/// Error tolerance
/// Error tolerance
double
error_tolerance
double
error_tolerance
