O
Chaofan Chen
0c48a469
0c48a469
2 years ago
Dmitri Naumov
[PL/CT] Add Residuum output for all variables
b8420433
Branches containing commit
2
2 changed files
ProcessLib/ComponentTransport/ComponentTransportProcess.cpp
+21
-6
21 additions, 6 deletions
ProcessLib/ComponentTransport/ComponentTransportProcess.h
+1
-1
1 addition, 1 deletion
22 additions
7 deletions
21
6
0c48a469
@@ -21,6 +21,7 @@
#include
"NumLib/DOF/ComputeSparsityPattern.h"
#include
"ProcessLib/SurfaceFlux/SurfaceFlux.h"
#include
"ProcessLib/SurfaceFlux/SurfaceFluxData.h"
#include
"ProcessLib/Utils/ComputeResiduum.h"
#include
"ProcessLib/Utils/CreateLocalAssemblers.h"
namespace
ProcessLib
@@ -48,9 +49,14 @@ ComponentTransportProcess::ComponentTransportProcess(
_surfaceflux
std
move
surfaceflux
_chemical_solver_interface
std
move
// Todo(renchao): Need to adapt for the multi-component case.
_molar_flow_rate
MeshLib
getOrCreateMeshProperty
double
mesh
"MolarFlowRate"
MeshLib
MeshItemType
Node
std
size_t
n_processes
_process_variables
size
_molar_flow_rate
resize
n_processes
for
int
process_id
process_id
n_processes
process_id
_molar_flow_rate
process_id
MeshLib
double
mesh
"MolarFlowRate_"
std
to_string
process_id
MeshLib
MeshItemType
Node
void
initializeConcreteProcess
@@ -170,6 +176,15 @@ void ComponentTransportProcess::assembleConcreteProcess(
_global_assembler
VectorMatrixAssembler
assemble
_local_assemblers
pv
getActiveElementIDs
dof_tables
t
dt
x
xdot
process_id
M
K
b
MathLib
finalizeMatrixAssembly
M
MathLib
K
MathLib
finalizeVectorAssembly
b
auto
const
residuum
computeResiduum
x
xdot
M
K
b
transformVariableFromGlobalVector
residuum
_local_to_global_index_map
_molar_flow_rate
process_id
std
negate
double
void
assembleWithJacobianConcreteProcess
@@ -201,9 +216,9 @@ void ComponentTransportProcess::assembleWithJacobianConcreteProcess(
// b is the negated residumm used in the Newton's method.
// Here negating b is to recover the primitive residuum.
b
/*variable id*/
_molar_flow_rate
std
negate
double
b
process_id
_molar_flow_rate
process_id
std
negate
double
Eigen
Vector3d
getFlux
0c48a469
@@ -170,7 +170,7 @@ private:
std
unique_ptr
ChemistryLib
ChemicalSolverInterface
MeshLib
PropertyVector
double
_molar_flow_rate
nullptr
std
vector
MeshLib
PropertyVector
double
_molar_flow_rate
// namespace ComponentTransport
