Commit 1d56ce52 authored by wenqing's avatar wenqing Committed by Lars Bilke
[Bbar#M] Jupyter Notebook benchmark to evaluate the
B-bar method with simple examples
parent ebdb0ab0
with 1368 additions and 0 deletions
...@@ -353,6 +353,7 @@ AddTest( ...@@ -353,6 +353,7 @@ AddTest(
if(NOT OGS_USE_PETSC) if(NOT OGS_USE_PETSC)
NotebookTest(NOTEBOOKFILE Mechanics/CooksMembrane/CooksMembraneBbar.ipynb RUNTIME 1) NotebookTest(NOTEBOOKFILE Mechanics/CooksMembrane/CooksMembraneBbar.ipynb RUNTIME 1)
NotebookTest(NOTEBOOKFILE Mechanics/Linear/SimpleMechanics.ipynb RUNTIME 5) NotebookTest(NOTEBOOKFILE Mechanics/Linear/SimpleMechanics.ipynb RUNTIME 5)
NotebookTest(NOTEBOOKFILE Mechanics/EvaluatingBbarWithSimpleExamples/evaluating_bbbar_with_simple_examples.ipynb RUNTIME 5)
NotebookTest(NOTEBOOKFILE Mechanics/Linear/DiscWithHole/Linear_Disc_with_hole.md RUNTIME 15) NotebookTest(NOTEBOOKFILE Mechanics/Linear/DiscWithHole/Linear_Disc_with_hole.md RUNTIME 15)
if(NOT WIN32) if(NOT WIN32)
NotebookTest(NOTEBOOKFILE Mechanics/Linear/DiscWithHole/Linear_Disc_with_hole_convergence_analysis.ipynb RUNTIME 40) NotebookTest(NOTEBOOKFILE Mechanics/Linear/DiscWithHole/Linear_Disc_with_hole_convergence_analysis.ipynb RUNTIME 40)
Tests/Data/Mechanics/EvaluatingBbarWithSimpleExamples/figures/quad_M_fig.png
24.7 KiB
Tests/Data/Mechanics/EvaluatingBbarWithSimpleExamples/figures/quad_M_fig_homo.png
25.1 KiB
<?xml version="1.0" encoding="utf-8"?>
<OpenGeoSysGLI>
<name>geometry</name>
<points>
<point id="0" x="0." y="0." z="0." name = "origin"/>
<point id="1" x="1.0" y="0.0" z="0." />
<point id="2" x="1.0" y="1.0" z="0." />
<point id="3" x="0." y="1.0" z="0." />
</points>
<polylines>
<polyline id="1" name="bottom">
<pnt>0</pnt>
<pnt>1</pnt>
</polyline>
<polyline id="2" name="top">
<pnt>2</pnt>
<pnt>3</pnt>
</polyline>
</polylines>
</OpenGeoSysGLI>
<?xml version="1.0"?>
<VTKFile type="UnstructuredGrid" version="1.0" byte_order="LittleEndian" header_type="UInt64">
<UnstructuredGrid>
<Piece NumberOfPoints="21" NumberOfCells="4" >
<PointData>
</PointData>
<CellData>
<DataArray type="Int32" Name="MaterialIDs" format="appended" RangeMin="0" RangeMax="0" offset="0" />
</CellData>
<Points>
<DataArray type="Float64" Name="Points" NumberOfComponents="3" format="appended" RangeMin="0" RangeMax="1.4142135624" offset="32" />
</Points>
<Cells>
<DataArray type="Int64" Name="connectivity" format="appended" RangeMin="" RangeMax="" offset="716" />
<DataArray type="Int64" Name="offsets" format="appended" RangeMin="" RangeMax="" offset="1068" />
<DataArray type="UInt8" Name="types" format="appended" RangeMin="" RangeMax="" offset="1124" />
</Cells>
</Piece>
</UnstructuredGrid>
<AppendedData encoding="base64">
_EAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA+AEAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAADgPwAAAAAAAAAAAAAAAAAAAAAAAAAAAADwPwAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAOA/AAAAAAAAAAAAAAAAAADgPwAAAAAAAOA/AAAAAAAAAAAAAAAAAADwPwAAAAAAAOA/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAPA/AAAAAAAAAAAAAAAAAADgPwAAAAAAAPA/AAAAAAAAAAAAAAAAAADwPwAAAAAAAPA/AAAAAAAAAAAAAAAAAAAAAAAAAAAAANA/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAOg/AAAAAAAAAAAAAAAAAADQPwAAAAAAAAAAAAAAAAAAAAAAAAAAAADQPwAAAAAAAOA/AAAAAAAAAAAAAAAAAADQPwAAAAAAAPA/AAAAAAAAAAAAAAAAAADgPwAAAAAAANA/AAAAAAAAAAAAAAAAAADgPwAAAAAAAOg/AAAAAAAAAAAAAAAAAADoPwAAAAAAAAAAAAAAAAAAAAAAAAAAAADoPwAAAAAAAOA/AAAAAAAAAAAAAAAAAADoPwAAAAAAAPA/AAAAAAAAAAAAAAAAAADwPwAAAAAAANA/AAAAAAAAAAAAAAAAAADwPwAAAAAAAOg/AAAAAAAAAAA=AAEAAAAAAAAAAAAAAAAAAAEAAAAAAAAABAAAAAAAAAADAAAAAAAAAAsAAAAAAAAADgAAAAAAAAAMAAAAAAAAAAkAAAAAAAAAAQAAAAAAAAACAAAAAAAAAAUAAAAAAAAABAAAAAAAAAAQAAAAAAAAABMAAAAAAAAAEQAAAAAAAAAOAAAAAAAAAAMAAAAAAAAABAAAAAAAAAAHAAAAAAAAAAYAAAAAAAAADAAAAAAAAAAPAAAAAAAAAA0AAAAAAAAACgAAAAAAAAAEAAAAAAAAAAUAAAAAAAAACAAAAAAAAAAHAAAAAAAAABEAAAAAAAAAFAAAAAAAAAASAAAAAAAAAA8AAAAAAAAAIAAAAAAAAAAIAAAAAAAAABAAAAAAAAAAGAAAAAAAAAAgAAAAAAAAAA==BAAAAAAAAAAXFxcX
</AppendedData>
</VTKFile>
<OpenGeoSysProject>
<mesh>quad_edge_div_2.vtu</mesh>
<geometry>quad.gml</geometry>
<search_length_algorithm>
<type>fixed</type>
<value>1e-5</value>
</search_length_algorithm>
<processes>
<process>
<name>SD</name>
<type>SMALL_DEFORMATION</type>
<integration_order>3</integration_order>
<use_b_bar>true</use_b_bar>
<constitutive_relation>
<type>LinearElasticIsotropic</type>
<youngs_modulus>E</youngs_modulus>
<poissons_ratio>nu</poissons_ratio>
</constitutive_relation>
<specific_body_force>0 0</specific_body_force>
<process_variables>
<process_variable>displacement</process_variable>
</process_variables>
<secondary_variables>
<secondary_variable internal_name="epsilon" output_name="epsilon"/>
<secondary_variable internal_name="sigma" output_name="sigma"/>
</secondary_variables>
</process>
</processes>
<time_loop>
<processes>
<process ref="SD">
<nonlinear_solver>basic_newton</nonlinear_solver>
<convergence_criterion>
<type>PerComponentDeltaX</type>
<norm_type>NORM2</norm_type>
<reltols> 1.0e-9 1.0e-9 </reltols>
</convergence_criterion>
<time_discretization>
<type>BackwardEuler</type>
</time_discretization>
<time_stepping>
<type>FixedTimeStepping</type>
<t_initial> 0.0 </t_initial>
<t_end>1</t_end>
<timesteps>
<pair>
<repeat>1</repeat>
<delta_t>1</delta_t>
</pair>
</timesteps>
</time_stepping>
</process>
</processes>
<output>
<type>VTK</type>
<prefix>simple_b_bar_test</prefix>
<timesteps>
<pair>
<repeat> 1 </repeat>
<each_steps> 1 </each_steps>
</pair>
</timesteps>
<variables>
<variable>displacement</variable>
<variable>epsilon</variable>
<variable>sigma</variable>
</variables>
<suffix>_ts_{:timestep}_t_{:time}</suffix>
</output>
</time_loop>
<media>
<medium>
<phases>
<phase>
<type>Solid</type>
<properties>
<property>
<name>density</name>
<type>Parameter</type>
<parameter_name>rho</parameter_name>
</property>
</properties>
</phase>
</phases>
</medium>
</media>
<parameters>
<parameter>
<name>E</name>
<type>Constant</type>
<value>1.0E+10</value>
</parameter>
<parameter>
<name>nu</name>
<value>0.2</value>
</parameter>
<parameter>
<name>rho</name>
<value>0.0</value>
</parameter>
<parameter>
<name>zero</name>
<value>0.0</value>
</parameter>
<parameter>
<name>u0</name>
<values>0 0</values>
</parameter>
<parameter>
<name>load</name>
<values>-10e+6</values>
</parameter>
</parameters>
<process_variables>
<process_variable>
<name>displacement</name>
<components>2</components>
<order>2</order>
<initial_condition>u0</initial_condition>
<boundary_conditions>
<boundary_condition>
<geometrical_set>geometry</geometrical_set>
<geometry>bottom</geometry>
<type>Dirichlet</type>
<component>0</component>
<parameter>zero</parameter>
</boundary_condition>
<component>1</component>
<geometry>top</geometry>
<type>Neumann</type>
<parameter>load</parameter>
</boundary_conditions>
</process_variable>
<nonlinear_solvers>
<nonlinear_solver>
<name>basic_newton</name>
<type>Newton</type>
<max_iter>10</max_iter>
<linear_solver>general_linear_solver</linear_solver>
</nonlinear_solver>
</nonlinear_solvers>
<linear_solvers>
<linear_solver>
<name>general_linear_solver</name>
<eigen>
<solver_type>SparseLU</solver_type>
<scaling>true</scaling>
</eigen>
</linear_solver>
</linear_solvers>
</OpenGeoSysProject>
