Commit 344bda84 authored by joergbuchwald's avatar joergbuchwald
add preprocessor directives for Eigen version
parent b7df40a9
...@@ -386,7 +386,13 @@ std::unique_ptr<EigenLinearSolverBase> createIterativeSolver( ...@@ -386,7 +386,13 @@ std::unique_ptr<EigenLinearSolverBase> createIterativeSolver(
case EigenOption::SolverType::BiCGSTABL: case EigenOption::SolverType::BiCGSTABL:
#ifdef USE_EIGEN_UNSUPPORTED #ifdef USE_EIGEN_UNSUPPORTED
#if EIGEN_VERSION_AT_LEAST(3, 4, 90)
return createIterativeSolver<Eigen::BiCGSTABL>(precon_type); return createIterativeSolver<Eigen::BiCGSTABL>(precon_type);
#else
OGS_FATAL(
"BiCGSTABL requires at least Eigen version 3.4.90"
#endif
#else #else
OGS_FATAL( OGS_FATAL(
"The code is not compiled with the Eigen unsupported modules. " "The code is not compiled with the Eigen unsupported modules. "
...@@ -410,7 +416,13 @@ std::unique_ptr<EigenLinearSolverBase> createIterativeSolver( ...@@ -410,7 +416,13 @@ std::unique_ptr<EigenLinearSolverBase> createIterativeSolver(
case EigenOption::SolverType::IDRS: case EigenOption::SolverType::IDRS:
return createIterativeSolver<Eigen::IDRS>(precon_type); return createIterativeSolver<Eigen::IDRS>(precon_type);
#else
OGS_FATAL(
"IDRS requires at least Eigen version 3.4.90"
#endif
#else #else
...@@ -420,7 +432,13 @@ std::unique_ptr<EigenLinearSolverBase> createIterativeSolver( ...@@ -420,7 +432,13 @@ std::unique_ptr<EigenLinearSolverBase> createIterativeSolver(
case EigenOption::SolverType::IDRSTABL: case EigenOption::SolverType::IDRSTABL:
return createIterativeSolver<Eigen::IDRSTABL>(precon_type); return createIterativeSolver<Eigen::IDRSTABL>(precon_type);
#else
OGS_FATAL(
"IDRSTABL requires at least Eigen version 3.4.90"
#endif
#else #else
