O
Chaofan Chen
6905584f
6905584f
1 year ago
Julian Heinze
Moved docu to header + adjusted for doxygen
16db77d7
2
2 changed files
MeshToolsLib/MeshGenerators/VoxelGridFromMesh.cpp
+3
-8
3 additions, 8 deletions
MeshToolsLib/MeshGenerators/VoxelGridFromMesh.h
+6
-0
6 additions, 0 deletions
9 additions
8 deletions
3
8
6905584f
@@ -28,12 +28,6 @@
@@ -28,12 +28,6 @@
namespace
MeshToolsLib
MeshGenerator
VoxelGridFromMesh
namespace
MeshToolsLib
MeshGenerator
VoxelGridFromMesh
// getNumberOfVoxelPerDimension is used to calculate how many voxel fit to
// a bounding box. For this calculation the differnce of min and max point of
// the bounding box is devided by the cellsize, for every dimension. The
// calculation is restricted to work only with positive values for the cellsize.
// If the there is no differencec in min and max, we assign one voxel for the
// respective dimension.
std
array
std
size_t
3
std
array
std
size_t
3
std
array
double
3
const
ranges
std
array
double
3
const
cellsize
std
array
double
3
const
ranges
std
array
double
3
const
cellsize
@@ -42,8 +36,9 @@ std::array<std::size_t, 3> getNumberOfVoxelPerDimension(
OGS_FATAL
"A cellsize ({},{},{}) is not allowed to be <= 0"
OGS_FATAL
cellsize
cellsize
cellsize
2
cellsize
cellsize
cellsize
2
std
array
double
3
numberOfVoxel
std
array
double
3
numberOfVoxel
ranges
cellsize
ranges
cellsize
ranges
cellsize
ranges
2
cellsize
2
ranges
cellsize
ranges
2
cellsize
2
if
ranges
ranges
ranges
2
if
ranges
ranges
ranges
2
6
6905584f
@@ -29,6 +29,12 @@ namespace MeshToolsLib::MeshGenerator::VoxelGridFromMesh
static
std
string
const
cell_id_name
"CellIds"
static
std
string
const
cell_id_name
"CellIds"
/// getNumberOfVoxelPerDimension is used to calculate how many voxel fit into
/// a bounding box. For this calculation the difference of min and max point of
/// the bounding box is divided by the cell size, for every dimension. The
/// calculation is restricted to work only with positive values for the cell
/// size. If the difference between min and max is zero, we assign one voxel for
/// the respective dimension.
std
array
std
size_t
3
std
array
std
size_t
3
std
array
double
3
const
ranges
std
array
double
3
const
cellsize
std
array
double
3
const
ranges
std
array
double
3
const
cellsize
