O
Chaofan Chen
7d00c92b
7d00c92b
6 years ago
Dmitri Naumov
[BL] Add removeFiles().
970229ff
Branches containing commit
Tags containing commit
2
2 changed files
BaseLib/FileTools.cpp
+22
-0
22 additions, 0 deletions
BaseLib/FileTools.h
+4
-1
4 additions, 1 deletion
BaseLib/FileTools.h
26 additions
1 deletion
22
7d00c92b
@@ -204,4 +204,26 @@ void setProjectDirectory(std::string const& dir)
project_directory_is_set
true
true
void
removeFiles
std
vector
std
string
const
files
for
auto
const
file
files
int
const
success
std
remove
file
c_str
if
success
DBUG
"Removed '%s'"
file
c_str
else
if
errno
ENOENT
// File does not exists
continue
ERR
"Removing file '%s' failed with error %d."
file
c_str
errno
std
perror
"Error: "
OGS_FATAL
"Unrecoverable error happened while removing a file."
// end namespace BaseLib
BaseLib/FileTools.h
4
7d00c92b
@@ -167,4 +167,7 @@ std::string const& getProjectDirectory();
/// Sets the project directory.
void
setProjectDirectory
std
string
const
dir
void
setProjectDirectory
std
string
const
dir
/// Remove files. If a file does not exist nothing will happen, other errors
/// lead to OGS_FATAL call.
void
removeFiles
std
vector
std
string
const
files
