Commit a51dcfdf authored by Lars Bilke's avatar Lars Bilke
[web] Document registry.opengeosys.org/ogs/ogs/ogs-petsc-jupyter image.
parent 943a5c4a
......@@ -15,10 +15,12 @@ weight = 5
## Jupyter Notebooks container environments
You can use a pre-defined container environment which currently contains:
You can use a pre-defined container environment.
Image `registry.opengeosys.org/ogs/ogs/ogs-serial-jupyter` contains:
- The Jupyter Notebook / Lab application
- The latest OpenGeoSys application (with MFront support) and tools
- The latest OpenGeoSys application with MFront-support and tools
- A set of Python packages:
- [ogs6py](https://github.com/joergbuchwald/ogs6py) — OGS model manipulation
- [VTUInterface](https://github.com/joergbuchwald/VTUinterface) — VTU / PVD IO
......@@ -34,6 +36,11 @@ You can use a pre-defined container environment which currently contains:
- [nbconvert](https://nbconvert.readthedocs.io) — Format conversion
- [nbdime](https://nbdime.readthedocs.io) — Diffs for notebooks
- [nb2hugo](https://github.com/bilke/nb2hugo/tree/ogs) — Notebook to www.opengeosys.org markdown
Image `registry.opengeosys.org/ogs/ogs/ogs-petsc-jupyter` additionally contains:
- PETSc-support
### Usage
With [Docker]({{< ref "container.md#with-docker" >}}):
......@@ -43,7 +50,7 @@ docker run --rm -p 8888:8888 -v $PWD:/home/jovyan/work --user `id -u $USER` \
--group-add users registry.opengeosys.org/ogs/ogs/ogs-serial-jupyter
This mounts your current directory into `~/work` inside the container.
This mounts your current directory into `~/work` inside the container. Use image `registry.opengeosys.org/ogs/ogs/ogs-petsc-jupyter` for PETSc-support!
<div class="note">
