Commit a5893803 authored by Lars Bilke's avatar Lars Bilke Committed by Dmitri Naumov
Use TARGET_FILE generator expression for vtkdiff.
parent ac0ea39f
...@@ -45,7 +45,7 @@ function (OgsTest) ...@@ -45,7 +45,7 @@ function (OgsTest)
# COMMAND ogs -r ${OgsTest_SOURCE_DIR} ${OgsTest_SOURCE_DIR}/${OgsTest_NAME}") # COMMAND ogs -r ${OgsTest_SOURCE_DIR} ${OgsTest_SOURCE_DIR}/${OgsTest_NAME}")
set_tests_properties(${TEST_NAME} PROPERTIES ENVIRONMENT set_tests_properties(${TEST_NAME} PROPERTIES ENVIRONMENT
VTKDIFF_EXE=${CMAKE_BINARY_DIR}/bin/vtkdiff) VTKDIFF_EXE=$<TARGET_FILE:vtkdiff>)
if(TARGET ${OgsTest_EXECUTABLE}) if(TARGET ${OgsTest_EXECUTABLE})
add_dependencies(ctest ${OgsTest_EXECUTABLE}) add_dependencies(ctest ${OgsTest_EXECUTABLE})
