O
Chaofan Chen
a8dc6e61
a8dc6e61
3 years ago
Tom Fischer
[T/MaL] Adjustment to new LinearSolverOptionsParser.
bee0ed51
3
3 changed files
Tests/MathLib/TestLinearSolver.cpp
+18
-8
18 additions, 8 deletions
Tests/NumLib/TestODEInt.cpp
+19
-11
19 additions, 11 deletions
Tests/NumLib/TestSerialLinearSolver.cpp
+6
-1
6 additions, 1 deletion
43 additions
20 deletions
18
8
a8dc6e61
@@ -20,19 +20,18 @@
@@ -20,19 +20,18 @@
#include
"MathLib/LinAlg/Eigen/EigenLinearSolver.h"
#include
#include
"MathLib/LinAlg/Eigen/EigenMatrix.h"
#include
#include
"MathLib/LinAlg/Eigen/EigenVector.h"
#include
#include
"MathLib/LinAlg/Eigen/LinearSolverOptionsParser.h"
#include
"MathLib/LinAlg/FinalizeMatrixAssembly.h"
#include
#include
"MathLib/LinAlg/LinAlg.h"
#include
#if defined(USE_LIS)
#include
"MathLib/LinAlg/EigenLis/EigenLisLinearSolver.h"
#endif
#ifdef USE_LIS
#ifdef USE_LIS
#include
"MathLib/LinAlg/Lis/LisLinearSolver.h"
#include
#include
"MathLib/LinAlg/EigenLis/LinearSolverOptionsParser.h"
#include
"MathLib/LinAlg/Lis/LisVector.h"
#include
#endif
#endif
#ifdef USE_PETSC
#ifdef USE_PETSC
#include
"MathLib/LinAlg/PETSc/LinearSolverOptionsParser.h"
#include
"MathLib/LinAlg/PETSc/PETScLinearSolver.h"
#include
#include
"MathLib/LinAlg/PETSc/PETScMatrix.h"
#include
#include
"MathLib/LinAlg/PETSc/PETScVector.h"
#include
@@ -208,8 +207,12 @@ void checkLinearSolverInterface(T_MATRIX& A,
MathLib
finalizeMatrixAssembly
A
MathLib
A
// solve
auto
const
linear_solver_parser
T_LINEAR_SOLVER
ls
"dummy_name"
ls_option
MathLib
T_LINEAR_SOLVER
auto
const
solver_options
parseNameAndOptions
ls_option
T_LINEAR_SOLVER
ls
std
get
solver_options
std
get
solver_options
ls
solve
A
rhs
x
ls
solve
A
rhs
x
ASSERT_ARRAY_NEAR
ex1
exH
x
ex1
dim_eqs
1e-5
ASSERT_ARRAY_NEAR
ex1
exH
x
ex1
dim_eqs
1e-5
@@ -273,7 +276,12 @@ void checkLinearSolverInterface(T_MATRIX& A, T_VECTOR& b,
// solve
// solve
T_VECTOR
y
b
deep_copy
T_VECTOR
y
b
deep_copy
y
setZero
y
setZero
T_LINEAR_SOLVER
ls
prefix_name
ls_option
std
string
temp_prefix_name
prefix_name
auto
const
solver_options
MathLib
T_LINEAR_SOLVER
parseNameAndOptions
std
move
temp_prefix_name
ls_option
T_LINEAR_SOLVER
ls
std
get
solver_options
std
get
solver_options
EXPECT_TRUE
ls
solve
A
b
y
EXPECT_TRUE
ls
solve
A
b
y
EXPECT_GT
ls
getNumberOfIterations
0u
EXPECT_GT
ls
0u
@@ -286,6 +294,7 @@ void checkLinearSolverInterface(T_MATRIX& A, T_VECTOR& b,
// end namespace
// end namespace
#if not defined(USE_LIS) and not defined(USE_PETSC)
TEST
Math
CheckInterface_Eigen
TEST
Math
// set solver options using Boost property tree
@@ -305,6 +314,7 @@ TEST(Math, CheckInterface_Eigen)
MathLib
EigenMatrix
MathLib
EigenVector
MathLib
EigenMatrix
MathLib
EigenVector
MathLib
EigenLinearSolver
IntType
A
conf
MathLib
EigenLinearSolver
IntType
A
conf
#endif
TEST
Math
CheckInterface_EigenLis
TEST
Math
19
11
a8dc6e61
@@ -25,23 +25,31 @@
@@ -25,23 +25,31 @@
namespace
TestODEInt
namespace
TestODEInt
#ifndef USE_PETSC
#if defined(USE_PETSC)
std
unique_ptr
GlobalLinearSolver
createLinearSolver
std
string
const
petsc_options
"-ksp_type bcgs -pc_type sor -ksp_rtol 1e-24 -ksp_max_it 100 "
"-ksp_initial_guess_nonzero false"
return
std
make_unique
GlobalLinearSolver
petsc_options
#elif defined(USE_LIS)
std
unique_ptr
GlobalLinearSolver
createLinearSolver
std
unique_ptr
GlobalLinearSolver
createLinearSolver
return
std
make_unique
GlobalLinearSolver
nullptr
auto
const
solver_options
MathLib
GlobalLinearSolver
parseNameAndOptions
nullptr
return
std
make_unique
GlobalLinearSolver
std
get
solver_options
std
get
solver_options
#else
#else
std
unique_ptr
GlobalLinearSolver
createLinearSolver
std
unique_ptr
GlobalLinearSolver
createLinearSolver
const
char
xml
auto
const
solver_options
"<petsc><parameters>"
MathLib
GlobalLinearSolver
parseNameAndOptions
nullptr
return
std
make_unique
GlobalLinearSolver
std
get
solver_options
"</parameters></petsc>"
std
get
solver_options
auto
const
ptree
Tests
readXml
xml
BaseLib
ConfigTree
config
ptree
BaseLib
ConfigTree
onerror
BaseLib
ConfigTree
onwarning
return
std
make_unique
GlobalLinearSolver
config
#endif
#endif
6
a8dc6e61
@@ -127,7 +127,12 @@ TEST(NumLibSerialLinearSolver, Steady2DdiffusionQuadElem)
BaseLib
ConfigTree
conf
t_root
BaseLib
ConfigTree
onerror
BaseLib
ConfigTree
conf
t_root
BaseLib
ConfigTree
onerror
BaseLib
ConfigTree
onwarning
BaseLib
ConfigTree
onwarning
GlobalLinearSolver
ls
"solver_name"
conf
auto
const
MathLib
GlobalLinearSolver
auto
const
solver_options
parseNameAndOptions
conf
GlobalLinearSolver
ls
std
get
solver_options
std
get
solver_options
ls
solve
A
rhs
x
ls
solve
A
rhs
x
// copy solution to double vector
