O
Chaofan Chen
af2ce73e
af2ce73e
1 year ago
Christoph Lehmann
[MPL] Made function property thread safe
5382e6ce
2
2 changed files
MaterialLib/MPL/Properties/Function.cpp
+13
-7
13 additions, 7 deletions
MaterialLib/MPL/Properties/Function.h
+2
-0
2 additions, 0 deletions
15 additions
7 deletions
13
7
af2ce73e
@@ -77,13 +77,18 @@ static void updateVariableValues(
static
PropertyDataType
evaluateExpressions
static
PropertyDataType
evaluateExpressions
std
vector
std
pair
Variable
double
const
symbol_values
std
vector
std
pair
Variable
double
const
symbol_values
VariableArray
const
variable_array
VariableArray
const
variable_array
std
vector
exprtk
expression
double
const
expressions
std
vector
exprtk
expression
double
const
expressions
std
mutex
mutex
symbol_values
variable_array
std
vector
double
result
expressions
size
std
vector
double
result
expressions
size
std
transform
begin
expressions
end
expressions
begin
result
auto
const
e
return
e
value
std
lock_guard
lock_guard
mutex
symbol_values
variable_array
std
transform
begin
expressions
end
expressions
begin
result
auto
const
e
return
e
value
switch
result
size
switch
result
size
@@ -187,7 +192,7 @@ PropertyDataType Function::value(VariableArray const& variable_array,
double
const
/*t*/
double
const
/*dt*/
const
double
const
/*t*/
double
const
/*dt*/
const
return
evaluateExpressions
symbol_values_
variable_array
return
evaluateExpressions
symbol_values_
variable_array
value_expressions_
value_expressions_
mutex_
PropertyDataType
Function
dValue
VariableArray
const
variable_array
PropertyDataType
Function
dValue
VariableArray
const
variable_array
@@ -208,7 +213,8 @@ PropertyDataType Function::dValue(VariableArray const& variable_array,
variable_enum_to_string
static_cast
int
variable
name_
static_cast
int
variable
name_
return
evaluateExpressions
symbol_values_
variable_array
it
second
return
evaluateExpressions
symbol_values_
variable_array
it
second
mutex_
// namespace MaterialPropertyLib
2
af2ce73e
@@ -55,5 +55,7 @@ private:
/// Multiple expressions are representing vector-valued functions.
std
vector
std
pair
Variable
std
vector
Expression
std
vector
std
pair
Variable
std
vector
Expression
dvalue_expressions_
dvalue_expressions_
mutable
std
mutex
mutex_
