You may use this container on e.g. `envinf1` with X11 forwarding (`ssh -XY envinf1`).
## With Docker
Although Singularity is the preferred container runtime you can use [Docker](https://www.docker.com) too.
### Prerequisites
* A running [installation of Docker](https://docs.docker.com/get-docker/)
### Run OGS inside a Docker container
* Get the container: `docker pull registry.opengeosys.org/ogs/ogs/ogs-serial`
* Start interactive container session: `docker run --rm -it registry.opengeosys.org/ogs/ogs/ogs-serial`
* Run ogs: `/scif/apps/ogs/bin/ogs --version`
* Exit the container: `exit`
You will notice that the interactive session in your container is isolated from your host, i.e. you do not have access to files on your host. You need to explicitly [mount](https://docs.docker.com/storage/bind-mounts/) them on `docker run`:
```bash
mkdir ~/ogs_out
docker run --rm -it -v $HOME/code/ogs6/ogs/Tests/Data:/tmp/data:ro -v $HOME/ogs_out:/tmp/out registry.opengeosys.org/ogs/ogs/ogs-seria
