Commit c088c68f authored by Tom Fischer's avatar Tom Fischer
[MeL/IO/XDMF/XdmfHdfWriter] Code quality improvements
- Make constant_output_names a local std::array
- Initialize the array with initializer list instead of insert in previous version
parent 1b4847a6
......@@ -11,6 +11,7 @@
#include <algorithm>
#include <functional>
#include <range/v3/algorithm/contains.hpp>
#include "BaseLib/Algorithm.h"
#include "InfoLib/GitInfo.h"
......@@ -39,13 +40,22 @@ struct XdmfHdfMesh final
template <typename Data>
std::function<bool(Data)> isVariableAttribute(
std::set<std::string> const& variable_output_names,
std::set<std::string> const& constant_output_names)
std::set<std::string> const& variable_output_names)
if (variable_output_names.empty())
return [&constant_output_names](Data const& data) -> bool
{ return !constant_output_names.contains(data.name); };
return [](Data const& data) -> bool
constexpr std::array constant_output_names{
"MaterialIDs"sv,
"topology"sv,
"geometry"sv,
MeshLib::getBulkIDString(MeshLib::MeshItemType::Node),
MeshLib::getBulkIDString(MeshLib::MeshItemType::Cell),
MeshLib::getBulkIDString(MeshLib::MeshItemType::Edge),
MeshLib::getBulkIDString(MeshLib::MeshItemType::Face)};
return !ranges::contains(constant_output_names, data.name);
return [&variable_output_names](Data const& data) -> bool
{ return variable_output_names.contains(data.name); };
......@@ -61,17 +71,6 @@ XdmfHdfWriter::XdmfHdfWriter(
// ogs meshes to vector of Xdmf/HDF meshes (we keep Xdmf and HDF together
// because XDMF depends on HDF) to meta
std::set<std::string> constant_output_names;
for (std::string_view item :
{"MaterialIDs"sv, "topology"sv, "geometry"sv,
MeshLib::getBulkIDString(MeshLib::MeshItemType::Face)})
constant_output_names.insert(std::string(item));
// if no output name is specified, all data will be assumened to be
// variable over the timesteps. The xdmfhdfwriter is an alternative to
// other writers, that do not consider the constantness of data Callers
......@@ -113,8 +112,8 @@ XdmfHdfWriter::XdmfHdfWriter(
std::move(attributes), mesh.get().getName(),
std::move(xdmf_conforming_data)};
auto isVariableHdfAttribute = isVariableAttribute<HdfData>(
variable_output_names, constant_output_names);
isVariableAttribute<HdfData>(variable_output_names);
// extract meta data relevant for HDFWriter
auto const transform_metamesh_to_hdf =
......@@ -172,8 +171,8 @@ XdmfHdfWriter::XdmfHdfWriter(
return;
auto isVariableXdmfAttribute = isVariableAttribute<XdmfData>(
isVariableAttribute<XdmfData>(variable_output_names);
// xdmf section
// extract meta data relevant for XDMFWriter
auto const transform_metamesh_to_xdmf =
