Commit cefadffa authored by Tom Fischer's avatar Tom Fischer
[file SimpleTests/MatrixTests/MatMult.cpp]
- added TCLAP library to parse command line arguments
parent 74d2ab4d
* MatMult.cpp
* Created on: Jan 3, 2012
* Author: TF
#include <fstream> #include <fstream>
#include <iostream> #include <iostream>
#include <cmath> #include <cmath>
...@@ -7,9 +14,12 @@ ...@@ -7,9 +14,12 @@
#include "LinAlg/Sparse/CRSMatrix.h" #include "LinAlg/Sparse/CRSMatrix.h"
#include "LinAlg/Sparse/CRSMatrixOpenMP.h" #include "LinAlg/Sparse/CRSMatrixOpenMP.h"
#include "LinAlg/Sparse/CRSMatrixPThreads.h" #include "LinAlg/Sparse/CRSMatrixPThreads.h"
// BaseLib
#include "RunTime.h" #include "RunTime.h"
#include "CPUTime.h" #include "CPUTime.h"
#include "logog.hpp" #include "logog.hpp"
#include "tclap/CmdLine.h"
#ifdef _OPENMP #ifdef _OPENMP
#include <omp.h> #include <omp.h>
...@@ -18,40 +28,57 @@ ...@@ -18,40 +28,57 @@
int main(int argc, char *argv[]) int main(int argc, char *argv[])
LOGOG_INITIALIZE(); LOGOG_INITIALIZE();
logog::Cout* logogCout = new logog::Cout;
if (argc < 4) { TCLAP::CmdLine cmd("Simple matrix vector multiplication test", ' ', "0.1");
std::cout << "Usage: " << argv[0] << " num_of_threads matrix number_of_multiplications resultfile" << std::endl;
INFO("Usage: %s num_of_threads matrix number_of_multiplications resultfile", argv[0]);
exit (1);
// read number of threads // Define a value argument and add it to the command line.
unsigned n_threads (1); // A value arg defines a flag and a type of value that it expects,
n_threads = atoi (argv[1]); // such as "-m matrix".
TCLAP::ValueArg<std::string> matrix_arg("m", "matrix", "input matrix file", true, "", "string");
// Add the argument mesh_arg to the CmdLine object. The CmdLine object
// uses this Arg to parse the command line.
cmd.add( matrix_arg );
TCLAP::ValueArg<unsigned> n_cores_arg("p", "number-cores", "number of cores to use", false, 1, "number");
cmd.add( n_cores_arg );
TCLAP::ValueArg<unsigned> n_mults_arg("n", "number-of-multiplications", "number of multiplications to perform", true, 10, "number");
cmd.add( n_mults_arg );
TCLAP::ValueArg<std::string> output_arg("o", "output", "output file", false, "", "string");
cmd.add( output_arg );
TCLAP::ValueArg<unsigned> verbosity_arg("v", "verbose", "level of verbosity [0 very low information, 1 much information]", false, 0, "string");
cmd.add( verbosity_arg );
cmd.parse( argc, argv );
// read the number of multiplication to execute // read the number of multiplication to execute
unsigned n_mults (0); unsigned n_mults (n_mults_arg.getValue());
n_mults = atoi (argv[3]); std::string fname_mat (matrix_arg.getValue());
std::string fname_mat (argv[2]); logog::Cout* logogCout = new logog::Cout;
unsigned n_threads (n_cores_arg.getValue());
// *** reading matrix in crs format from file // *** reading matrix in crs format from file
std::ifstream in(fname_mat.c_str(), std::ios::in | std::ios::binary); std::ifstream in(fname_mat.c_str(), std::ios::in | std::ios::binary);
double *A(NULL); double *A(NULL);
unsigned *iA(NULL), *jA(NULL), n; unsigned *iA(NULL), *jA(NULL), n;
if (in) { if (in) {
DBUG("reading matrix from %s ...", fname_mat.c_str()); INFO("reading matrix from %s ...", fname_mat.c_str());
BaseLib::RunTime timer; BaseLib::RunTime timer;
timer.start(); timer.start();
CS_read(in, n, iA, jA, A); CS_read(in, n, iA, jA, A);
timer.stop(); timer.stop();
DBUG("ok, %e s", timer.elapsed()); INFO("ok, %e s", timer.elapsed());
} else { } else {
ERR("error reading matrix from %s", fname_mat.c_str()); ERR("error reading matrix from %s", fname_mat.c_str());
unsigned nnz(iA[n]); unsigned nnz(iA[n]);
INFO("Parameters read: n=%i, nnz=%i", n, nnz); INFO("Parameters read: n=%d, nnz=%d", n, nnz);
omp_set_num_threads(n_threads); omp_set_num_threads(n_threads);
...@@ -60,7 +87,7 @@ int main(int argc, char *argv[]) ...@@ -60,7 +87,7 @@ int main(int argc, char *argv[])
MathLib::CRSMatrix<double, unsigned> mat (n, iA, jA, A); MathLib::CRSMatrix<double, unsigned> mat (n, iA, jA, A);
#endif #endif
// CRSMatrixPThreads<double> mat (n, iA, jA, A, n_threads); // CRSMatrixPThreads<double> mat (n, iA, jA, A, n_threads);
INFO("%i x %i", mat.getNRows(), mat.getNCols()); INFO("%d x %d", mat.getNRows(), mat.getNCols());
double *x(new double[n]); double *x(new double[n]);
double *y(new double[n]); double *y(new double[n]);
...@@ -68,7 +95,7 @@ int main(int argc, char *argv[]) ...@@ -68,7 +95,7 @@ int main(int argc, char *argv[])
for (unsigned k(0); k<n; ++k) for (unsigned k(0); k<n; ++k)
x[k] = 1.0; x[k] = 1.0;
DBUG("matrix vector multiplication with Toms amuxCRS (%i threads) ...", n_threads); INFO("matrix vector multiplication with Toms amuxCRS (%d threads) ...", n_threads);
BaseLib::RunTime run_timer; BaseLib::RunTime run_timer;
BaseLib::CPUTime cpu_timer; BaseLib::CPUTime cpu_timer;
run_timer.start(); run_timer.start();
...@@ -79,12 +106,12 @@ int main(int argc, char *argv[]) ...@@ -79,12 +106,12 @@ int main(int argc, char *argv[])
cpu_timer.stop(); cpu_timer.stop();
run_timer.stop(); run_timer.stop();
DBUG("done [%e sec cpu time], [%e sec run time]", cpu_timer.elapsed(), run_timer.elapsed()); INFO("done [%e sec cpu time], [%e sec run time]", cpu_timer.elapsed(), run_timer.elapsed());
DBUG("CPU time: %e", cpu_timer.elapsed()); INFO("CPU time: %e", cpu_timer.elapsed());
DBUG("wclock time: %e", run_timer.elapsed()); INFO("wclock time: %e", run_timer.elapsed());
if (argc == 5) { if (! output_arg.getValue().empty()) {
std::ofstream result_os (argv[4], std::ios::app); std::ofstream result_os (output_arg.getValue().c_str(), std::ios::app);
if (result_os) { if (result_os) {
result_os << cpu_timer.elapsed() << "\t" << run_timer.elapsed() << std::endl; result_os << cpu_timer.elapsed() << "\t" << run_timer.elapsed() << std::endl;
