Verified Commit dfa79449 authored by Lars Bilke's avatar Lars Bilke
[prj] Additional patch run after includes.
In the patch file you need to set the attribute after_includes="true"
on every patch step which should be executed after the include phase.
parent ece89a76
......@@ -17,7 +17,6 @@
#include <boost/property_tree/xml_parser.hpp>
#include <filesystem>
#include <iostream>
#include <regex>
#include "BaseLib/FileTools.h"
......@@ -128,15 +127,13 @@ void replaceIncludes(std::stringstream& prj_stream,
prj_stream.str(""); // Empty stream
prj_stream << xmlbuff;
// print for debugging
// std::cout << prj_stream.str() << std::endl;
xmlFree(xmlbuff);
xmlFreeDoc(doc);
// Applies a patch file to the prj content in prj_stream.
void patchStream(std::string patch_file, std::stringstream& prj_stream)
void patchStream(std::string patch_file, std::stringstream& prj_stream,
bool after_includes = false)
auto patch = xmlParseFile(patch_file.c_str());
if (patch == NULL)
......@@ -159,6 +156,28 @@ void patchStream(std::string patch_file, std::stringstream& prj_stream)
continue;
bool node_after_includes = false;
xmlAttr* attribute = node->properties;
while (attribute)
// Check for after_includes-attribute
xmlChar* value =
xmlNodeListGetString(node->doc, attribute->children, 1);
if (!strcmp(reinterpret_cast<const char*>(attribute->name),
"after_includes") &&
!strcmp(reinterpret_cast<const char*>(value), "true"))
node_after_includes = true;
xmlFree(value);
attribute = attribute->next;
if (after_includes != node_after_includes)
continue;
if (!strcmp(reinterpret_cast<const char*>(node->name), "add"))
......@@ -204,7 +223,7 @@ void patchStream(std::string patch_file, std::stringstream& prj_stream)
// Will set prj_file to the actual .prj file and returns the final prj file
// content in prj_stream.
void readAndPatchPrj(std::stringstream& prj_stream, std::string& prj_file,
std::vector<std::string> patch_files)
std::vector<std::string>& patch_files)
// Extract base project file path if an xml (patch) file is given as prj
// file and it contains the base_file attribute.
......@@ -266,8 +285,19 @@ ConfigTree makeConfigTree(const std::string& filepath,
std::string prj_file = filepath;
std::stringstream prj_stream;
readAndPatchPrj(prj_stream, prj_file, patch_files);
std::vector<std::string> patch_files_copy = patch_files;
readAndPatchPrj(prj_stream, prj_file, patch_files_copy);
replaceIncludes(prj_stream, std::filesystem::path(prj_file).parent_path());
// re-apply xml patches to stream
if (!patch_files_copy.empty())
for (const auto& patch_file : patch_files_copy)
patchStream(patch_file, prj_stream, true);
xmlCleanupParser();
ConfigTree::PTree ptree;
