Commit f4a60743 authored by Lars Bilke's avatar Lars Bilke Committed by Dmitri Naumov
[T] MPI tests in the testrunner are now part of the `tests`-target.
Was part of `tests_mpi`-target which was never tested in CI.
Tests will probably fail.
parent 1ea3dc38
......@@ -193,12 +193,9 @@ if(OGS_USE_PETSC)
set(TEST_FILTER_MPI --gtest_filter=-MPITest*)
add_custom_target(tests
mpirun ${MPIRUN_ARGS} -np 1 $<TARGET_FILE:testrunner> ${TESTRUNNER_ADDITIONAL_ARGUMENTS} ${TEST_FILTER_MPI}
COMMAND mpirun ${MPIRUN_ARGS} -np 3 $<TARGET_FILE:testrunner> --gtest_filter=MPITest*
DEPENDS testrunner tests-cleanup
add_custom_target(tests_mpi
DEPENDS testrunner
else()
