Unverified Commit 08d0f950 authored by Ludovic Courtès's avatar Ludovic Courtès
pull: Remove duplicate '--dry-run' description.
Reported by pkill9.
* guix/scripts/pull.scm (show-help): Remove duplicate '--dry-run'
description.
parent 238589e5
...@@ -91,8 +91,6 @@ (define (show-help) ...@@ -91,8 +91,6 @@ (define (show-help)
(display (G_ " (display (G_ "
-p, --profile=PROFILE use PROFILE instead of ~/.config/guix/current")) -p, --profile=PROFILE use PROFILE instead of ~/.config/guix/current"))
-n, --dry-run show what would be pulled and built"))
(display (G_ "
-v, --verbosity=LEVEL use the given verbosity LEVEL")) -v, --verbosity=LEVEL use the given verbosity LEVEL"))
-s, --system=SYSTEM attempt to build for SYSTEM--e.g., \"i686-linux\"")) -s, --system=SYSTEM attempt to build for SYSTEM--e.g., \"i686-linux\""))
