Commit 6ffd11f1 authored by Ludovic Courtès's avatar Ludovic Courtès
system: Prevent grub.cfg from being GC'd.
* guix/build/install.scm (install-grub): Use 'copy-file' instead of
  'symlink' for GRUB.CFG.
parent d5b429ab
...@@ -38,11 +38,18 @@ (define-module (guix build install) ...@@ -38,11 +38,18 @@ (define-module (guix build install)
(define* (install-grub grub.cfg device mount-point) (define* (install-grub grub.cfg device mount-point)
"Install GRUB with GRUB.CFG on DEVICE, which is assumed to be mounted on "Install GRUB with GRUB.CFG on DEVICE, which is assumed to be mounted on
MOUNT-POINT. Return #t on success." MOUNT-POINT. Return #t on success."
(mkdir-p (string-append mount-point "/boot/grub")) (let* ((target (string-append mount-point "/boot/grub/grub.cfg"))
(symlink grub.cfg (string-append mount-point "/boot/grub/grub.cfg")) (pivot (string-append target ".new")))
(zero? (system* "grub-install" "--no-floppy" (mkdir-p (dirname target))
"--boot-directory" (string-append mount-point "/boot")
device))) ;; Copy GRUB.CFG instead of just symlinking it since it's not a GC root.
;; Do that atomically.
(copy-file grub.cfg pivot)
(rename-file pivot target)
device))))
(define (evaluate-populate-directive directive target) (define (evaluate-populate-directive directive target)
"Evaluate DIRECTIVE, an sexp describing a file or directory to create under "Evaluate DIRECTIVE, an sexp describing a file or directory to create under
