Commit 9ba75ced authored by Christoph Lehmann's avatar Christoph Lehmann
[PL] optimization: less storage, less products
parent 00480c72
...@@ -36,23 +36,55 @@ protected: ...@@ -36,23 +36,55 @@ protected:
using NodalMatrixType = typename ShapeMatricesType::NodalMatrixType; using NodalMatrixType = typename ShapeMatricesType::NodalMatrixType;
using NodalVectorType = typename ShapeMatricesType::NodalVectorType; using NodalVectorType = typename ShapeMatricesType::NodalVectorType;
struct NAndWeight
NAndWeight(typename ShapeMatricesType::ShapeMatrices::ShapeType&& N_,
double const weight_)
: N(std::move(N_)), weight(weight_)
typename ShapeMatricesType::ShapeMatrices::ShapeType const N;
double const weight;
private:
static std::vector<NAndWeight, Eigen::aligned_allocator<NAndWeight>>
initNsAndWeights(MeshLib::Element const& e, bool is_axially_symmetric,
unsigned const integration_order)
IntegrationMethod const integration_method(integration_order);
ns_and_weights;
ns_and_weights.reserve(integration_method.getNumberOfPoints());
auto sms = initShapeMatrices<ShapeFunction, ShapeMatricesType,
IntegrationMethod, GlobalDim>(
e, is_axially_symmetric, integration_method);
for (unsigned ip = 0; ip < sms.size(); ++ip)
auto& sm = sms[ip];
double const w =
sm.detJ * sm.integralMeasure *
integration_method.getWeightedPoint(ip).getWeight();
ns_and_weights.emplace_back(std::move(sm.N), w);
return ns_and_weights;
public: public:
GenericNonuniformNaturalBoundaryConditionLocalAssembler( GenericNonuniformNaturalBoundaryConditionLocalAssembler(
MeshLib::Element const& e, bool is_axially_symmetric, MeshLib::Element const& e, bool is_axially_symmetric,
unsigned const integration_order) unsigned const integration_order)
: _integration_method(integration_order), : _ns_and_weights(
_shape_matrices(initShapeMatrices<ShapeFunction, ShapeMatricesType, initNsAndWeights(e, is_axially_symmetric, integration_order))
e, is_axially_symmetric, _integration_method))
protected: protected:
IntegrationMethod const _integration_method; std::vector<NAndWeight, Eigen::aligned_allocator<NAndWeight>> const
std::vector<typename ShapeMatricesType::ShapeMatrices, _ns_and_weights;
typename ShapeMatricesType::ShapeMatrices>> const
_shape_matrices;
} // ProcessLib } // ProcessLib
...@@ -61,9 +61,6 @@ public: ...@@ -61,9 +61,6 @@ public:
_local_rhs.setZero(); _local_rhs.setZero();
unsigned const n_integration_points =
Base::_integration_method.getNumberOfPoints();
auto indices = NumLib::getIndices(id, dof_table_boundary); auto indices = NumLib::getIndices(id, dof_table_boundary);
// TODO lots of heap allocations. // TODO lots of heap allocations.
...@@ -75,16 +72,15 @@ public: ...@@ -75,16 +72,15 @@ public:
_data.values.getComponent(i, 0)); _data.values.getComponent(i, 0));
auto const n_integration_points = Base::_ns_and_weights.size();
for (unsigned ip = 0; ip < n_integration_points; ip++) for (unsigned ip = 0; ip < n_integration_points; ip++)
auto const& sm = Base::_shape_matrices[ip]; auto const& n_and_weight = Base::_ns_and_weights[ip];
double flux; double flux;
NumLib::shapeFunctionInterpolate(neumann_param_nodal_values_local, NumLib::shapeFunctionInterpolate(neumann_param_nodal_values_local,
sm.N, flux); n_and_weight.N, flux);
auto const& wp = Base::_integration_method.getWeightedPoint(ip);
_local_rhs.noalias() += _local_rhs.noalias() +=
sm.N * flux * sm.detJ * wp.getWeight() * sm.integralMeasure; n_and_weight.N * (n_and_weight.weight * flux);
// map boundary dof indices to bulk dof indices // map boundary dof indices to bulk dof indices
