Commit e9fce28b authored by wenqing's avatar wenqing
[Test] Added a DECOVALEX-THMC based example for the staggered HT
parent 6b323554
...@@ -39,6 +39,20 @@ AddTest( ...@@ -39,6 +39,20 @@ AddTest(
VIS ConstViscosityThermalConvectionStaggeredAdaptive_dt_pcs_1_ts_135_t_50000000000.000000.vtu VIS ConstViscosityThermalConvectionStaggeredAdaptive_dt_pcs_1_ts_135_t_50000000000.000000.vtu
AddTest(
NAME HT_a_DECOVALEX_THMC_based_Example
PATH Parabolic/HT//StaggeredCoupling/ADecovalexTHMCBasedHTExample
EXECUTABLE ogs
EXECUTABLE_ARGS th_decovalex.prj
WRAPPER time
TESTER vtkdiff
REQUIREMENTS NOT (OGS_USE_LIS OR OGS_USE_MPI)
DIFF_DATA
th_decovalex.vtu th_decovalex_pcs_1_ts_40_t_18.000000.vtu T_ref T 1e-14 1.e-14
th_decovalex.vtu th_decovalex_pcs_1_ts_40_t_18.000000.vtu p_ref p 1e-14 1.e-14
VIS th_decovalex_pcs_1_ts_78_t_1000.000000.vtu
# MPI/PETSc tests # MPI/PETSc tests
AddTest( AddTest(
NAME Parallel_LARGE_2D_ThermalConvection_constviscosity NAME Parallel_LARGE_2D_ThermalConvection_constviscosity
...@@ -86,3 +100,17 @@ AddTest( ...@@ -86,3 +100,17 @@ AddTest(
square_5500x5500.vtu ConstViscosityThermalConvectionStaggeredAdaptive_dt_pcs_1_ts_135_t_50000000000_000000_0.vtu p_ref p 1e-3 1.e-3 square_5500x5500.vtu ConstViscosityThermalConvectionStaggeredAdaptive_dt_pcs_1_ts_135_t_50000000000_000000_0.vtu p_ref p 1e-3 1.e-3
VIS ConstViscosityThermalConvectionStaggeredAdaptive_dt_pcs_1_ts_135_t_50000000000_000000_0.vtu VIS ConstViscosityThermalConvectionStaggeredAdaptive_dt_pcs_1_ts_135_t_50000000000_000000_0.vtu
AddTest(
WRAPPER mpirun
WRAPPER_ARGS -np 1
TESTER vtkdiff
REQUIREMENTS OGS_USE_MPI
DIFF_DATA
th_decovalex.vtu th_decovalex_pcs_1_ts_40_t_18_000000_0.vtu T_ref T 1e-10 1.e-10
th_decovalex.vtu th_decovalex_pcs_1_ts_40_t_18_000000_0.vtu p_ref p 1e-10 1.e-10
VIS th_decovalex_pcs_1_ts_78_t_1000_000000_0.vtu
Source diff could not be displayed: it is stored in LFS. Options to address this: view the blob.
File added
