O
Yuhao Liu
8458616a
8458616a
3 years ago
Christoph Lehmann
Committed by
Dmitri Naumov
3 years ago
Rename local nlohmann_json::nlohmann_json target.
Naming it same as in an externally found library.
e2963065
Branches containing commit
3
3 changed files
Applications/ApplicationsLib/CMakeLists.txt
+1
-1
1 addition, 1 deletion
ProcessLib/CMakeLists.txt
+1
-1
scripts/cmake/Dependencies.cmake
+2
-2
2 additions, 2 deletions
4 additions
4 deletions
8458616a
@@ -23,7 +23,7 @@ if(OGS_BUILD_CLI OR OGS_BUILD_UTILS OR OGS_BUILD_TESTING)
PRIVATE ParameterLib ProcessLib
elseif
OGS_BUILD_GUI
elseif
OGS_BUILD_GUI
target_link_libraries
ApplicationsLib PRIVATE nlohmann_json
nlohmann_json::
nlohmann_json
endif
endif
if
OGS_USE_LIS
if
OGS_USE_LIS
8458616a
@@ -35,7 +35,7 @@ target_link_libraries(
NumLib
NumLib
$<$<TARGET_EXISTS:ProcessLibBoundaryConditionAndSourceTermPython>:ProcessLibBoundaryConditionAndSourceTermPython>
$<$<TARGET_EXISTS:petsc>:petsc>
nlohmann_json
nlohmann_json
::nlohmann_json
PRIVATE ParameterLib GitInfoLib $<$<TARGET_EXISTS:InSituLib>:InSituLib>
2
2
8458616a
@@ -307,9 +307,9 @@ CPMFindPackage(
SHA256=69cc88207ce91347ea530b227ff0776db82dcb8de6704e1a3d74f4841bc651cf
if
nlohmann_json_ADDED
if
nlohmann_json_ADDED
add_library
nlohmann_json INTERFACE IMPORTED
add_library
nlohmann_json
::nlohmann_json
INTERFACE IMPORTED
target_include_directories
nlohmann_json_SOURCE_DIR
nlohmann_json
::nlohmann_json
INTERFACE
endif
endif
