Commit 36742f43 authored by Ricardo Wurmus's avatar Ricardo Wurmus
gnu: Add Couger.
* gnu/packages/bioinformatics.scm (couger): New variable.
parent 0931c609
......@@ -34,6 +34,7 @@ (define-module (gnu packages bioinformatics)
#:use-module (gnu packages file)
#:use-module (gnu packages java)
#:use-module (gnu packages linux)
#:use-module (gnu packages machine-learning)
#:use-module (gnu packages maths)
#:use-module (gnu packages ncurses)
#:use-module (gnu packages perl)
......@@ -438,6 +439,76 @@ (define-public clipper
"CLIPper is a tool to define peaks in CLIP-seq datasets.")
(license license:gpl2)))
(define-public couger
(package
(name "couger")
(version "1.8.2")
(source (origin
(method url-fetch)
(uri (string-append
"http://couger.oit.duke.edu/static/assets/COUGER"
version ".zip"))
(sha256
(base32
"04p2b14nmhzxw5h72mpzdhalv21bx4w9b87z0wpw0xzxpysyncmq"))))
(build-system gnu-build-system)
(arguments
`(#:tests? #f
#:phases
(modify-phases %standard-phases
(delete 'configure)
(delete 'build)
(replace
'install
(lambda* (#:key outputs #:allow-other-keys)
(let ((out (assoc-ref outputs "out")))
(copy-recursively "src" (string-append out "/src"))
(mkdir (string-append out "/bin"))
;; Add "src" directory to module lookup path.
(substitute* "couger"
(("from argparse")
(string-append "import sys\nsys.path.append(\""
out "\")\nfrom argparse")))
(copy-file "couger" (string-append out "/bin/couger")))
#t))
(add-after
'install 'wrap-program
(lambda* (#:key inputs outputs #:allow-other-keys)
;; Make sure 'couger' runs with the correct PYTHONPATH.
(let* ((out (assoc-ref outputs "out"))
(path (getenv "PYTHONPATH")))
(wrap-program (string-append out "/bin/couger")
`("PYTHONPATH" ":" prefix (,path))))
#t)))))
(inputs
`(("python" ,python-2)
("python2-pillow" ,python2-pillow)
("python2-numpy" ,python2-numpy)
("python2-scipy" ,python2-scipy)
("python2-matplotlib" ,python2-matplotlib)))
(propagated-inputs
`(("r" ,r)
("libsvm" ,libsvm)
("randomjungle" ,randomjungle)))
(native-inputs
`(("unzip" ,unzip)))
(home-page "http://couger.oit.duke.edu")
(synopsis "Identify co-factors in sets of genomic regions")
(description
"COUGER can be applied to any two sets of genomic regions bound by
paralogous TFs (e.g., regions derived from ChIP-seq experiments) to identify
putative co-factors that provide specificity to each TF. The framework
determines the genomic targets uniquely-bound by each TF, and identifies a
small set of co-factors that best explain the in vivo binding differences
between the two TFs.
COUGER uses classification algorithms (support vector machines and random
forests) with features that reflect the DNA binding specificities of putative
co-factors. The features are generated either from high-throughput TF-DNA
binding data (from protein binding microarray experiments), or from large
collections of DNA motifs.")
(license license:gpl3+)))
(define-public clustal-omega
(package
(name "clustal-omega")
