Unverified Commit 43ec98ef authored by Giovanni Biscuolo's avatar Giovanni Biscuolo Committed by Ludovic Courtès
doc: use pure environment when building from git
* doc/contributing.texi (Building from Git): Add --pure to "guix environment"
  invocations
Signed-off-by: default avatarLudovic Courtès <ludo@gnu.org>
parent a9015747
...@@ -57,14 +57,14 @@ all the dependencies and appropriate environment variables are set up to ...@@ -57,14 +57,14 @@ all the dependencies and appropriate environment variables are set up to
hack on Guix: hack on Guix:
@example @example
guix environment guix guix environment guix --pure
@end example @end example
@xref{Invoking guix environment}, for more information on that command. @xref{Invoking guix environment}, for more information on that command.
Extra dependencies can be added with @option{--ad-hoc}: Extra dependencies can be added with @option{--ad-hoc}:
@example @example
guix environment guix --ad-hoc help2man git strace guix environment guix --pure --ad-hoc help2man git strace
Run @command{./bootstrap} to generate the build system infrastructure Run @command{./bootstrap} to generate the build system infrastructure
