Commit d9145a59 authored by Julian Heinze's avatar Julian Heinze
use function to remove bulk ids
parent ce732477
1 merge request!116bug fix - remove bulk_node/element_ids after assignment
Pipeline #22263 passed
...@@ -48,10 +48,9 @@ def get_specific_surface(surface_mesh: pv.PolyData, filter_condition): ...@@ -48,10 +48,9 @@ def get_specific_surface(surface_mesh: pv.PolyData, filter_condition):
def assign_bulk_ids(mesh: pv.UnstructuredGrid): def assign_bulk_ids(mesh: pv.UnstructuredGrid):
Add fields bulk_node_ids and bulk_element_ids to the given bulk mesh. Add data arrays for bulk_node_ids and bulk_element_ids to the given bulk mesh.
:param mesh_name: name of the mesh :param mesh: bulk mesh
:type mesh_name: str
# The format must be unsigned integer, as it is required by OGS # The format must be unsigned integer, as it is required by OGS
mesh["bulk_node_ids"] = np.arange(mesh.n_points, dtype=np.uint64) mesh["bulk_node_ids"] = np.arange(mesh.n_points, dtype=np.uint64)
...@@ -60,6 +59,16 @@ def assign_bulk_ids(mesh: pv.UnstructuredGrid): ...@@ -60,6 +59,16 @@ def assign_bulk_ids(mesh: pv.UnstructuredGrid):
def remove_bulk_ids(mesh: pv.UnstructuredGrid):
Remove data arrays for bulk_node_ids and bulk_element_ids of the given bulk mesh.
mesh.point_data.remove("bulk_node_ids")
mesh.cell_data.remove("bulk_element_ids")
def extract_point_boundary_conditions( def extract_point_boundary_conditions(
out_mesh_path: Path, mesh: pv.UnstructuredGrid out_mesh_path: Path, mesh: pv.UnstructuredGrid
...@@ -111,8 +120,7 @@ def extract_point_boundary_conditions( ...@@ -111,8 +120,7 @@ def extract_point_boundary_conditions(
str(out_mesh_path / point_data) + ".vtu" str(out_mesh_path / point_data) + ".vtu"
] = filtered_points ] = filtered_points
# Remove bulk node/element ids from bulk mesh, as they are not needed anymore. # Remove bulk node/element ids from bulk mesh, as they are not needed anymore.
mesh.point_data.remove("bulk_node_ids") remove_bulk_ids(mesh)
return dict_of_point_boundary_conditions return dict_of_point_boundary_conditions
...@@ -172,8 +180,7 @@ def extract_cell_boundary_conditions( ...@@ -172,8 +180,7 @@ def extract_cell_boundary_conditions(
# correct unit for P_IOFLOW, in FEFLOW m/d in ogs m/s # correct unit for P_IOFLOW, in FEFLOW m/d in ogs m/s
topsurf.cell_data["P_IOFLOW"] = topsurf.cell_data["P_IOFLOW"] topsurf.cell_data["P_IOFLOW"] = topsurf.cell_data["P_IOFLOW"]
return ( return (
bulk_mesh_path.with_stem("topsurface_" + bulk_mesh_path.stem), bulk_mesh_path.with_stem("topsurface_" + bulk_mesh_path.stem),
topsurf, topsurf,
