R
r2ogs6
Iterations
OpenGeoSys Tools
r2ogs6
67de87d1
67de87d1
4 years ago
Ruben Heinrich
[base]
#7
(subclass of process)
d049f295
2 merge requests
!4
7 parameter
!2
Basic import and export functionality
1 changed file
R/prj_porous_medium.R
+171
-0
171 additions, 0 deletions
171 additions
0 deletions
0 → 100644
171
67de87d1
#===== r2ogs6_porous_medium =====
#'r2ogs6_porous_medium
#'@description tag: porous_medium
#'@param id string | double:
#'@param permeability list:
#'@param porosity list:
#'@param storage list:
#'@param capillary_pressure r2ogs6_capillary_pressure:
#'@param relative_permeability list:
#'@export
function
id
permeability
porosity
storage
capillary_pressure
# COerce input
id
coerce_string_to_numeric
id
new_r2ogs6_porous_medium
id
permeability
porosity
storage
capillary_pressure
function
id
permeability
porosity
storage
capillary_pressure
validate_is_number
id
permeability
validate_param_list
permeability
c
"permeability_tensor_entries"
"type"
porosity
validate_param_list
porosity
c
"porosity_parameter"
"type"
storage
validate_param_list
storage
c
"value"
"type"
assertthat
assert_that
class
capillary_pressure
"r2ogs6_capillary_pressure"
assertthat
assert_that
is.list
for
i
in
seq_len
length
i
validate_param_list
i
c
"type"
"krel_min"
"m"
"smax"
"sr"
names
rep
"relative_permeability"
length
structure
list
id
id
permeability
permeability
porosity
porosity
storage
storage
capillary_pressure
capillary_pressure
is_subclass
TRUE
attr_names
c
"id"
flatten_on_exp
character
class
"r2ogs6_porous_medium"
#===== r2ogs6_capillary_pressure =====
#'r2ogs6_capillary_pressure
#'@description tag: capillary_pressure
#'@param type string:
#'@param pd Optional: string | double:
#'@param sr Optional: string | double:
#'@param smax Optional: string | double:
#'@param m Optional: string | double:
#'@param pc_max Optional: string | double:
#'@param has_regularized Optional: string, "true" | "false":
#'@param curve Optional: list:
#'@export
function
type
pd
NULL
sr
NULL
smax
NULL
m
NULL
pc_max
NULL
has_regularized
NULL
curve
NULL
# Coerce input
pd
pd
sr
sr
smax
smax
m
m
pc_max
pc_max
new_r2ogs6_capillary_pressure
type
pd
sr
smax
m
pc_max
has_regularized
curve
function
type
pd
NULL
sr
NULL
smax
NULL
m
NULL
pc_max
NULL
has_regularized
NULL
curve
NULL
validate_is_string
type
validate_is_null_or_number
pd
sr
smax
m
pc_max
validate_is_null_or_str_flag
has_regularized
validate_is_null_or_param_list
curve
c
"coords"
"values"
if
is.null
curve
curve
curve
TRUE
curve
2
curve
2
TRUE
assertthat
assert_that
is.numeric
curve
assertthat
assert_that
is.numeric
curve
2
structure
list
type
type
pd
pd
sr
sr
smax
smax
m
m
pc_max
pc_max
has_regularized
has_regularized
curve
curve
is_subclass
TRUE
attr_names
character
flatten_on_exp
character
class
